carb installation kit: whos installed one? - Page 2
This is a discussion on carb installation kit: whos installed one? within the Grom Performance forums, part of the Honda Grom Garage category; Originally Posted by m in sc yeah, im not liking that solution wit the box on the trees looks really cheey... if I get around ...
Results 11 to 17 of 17
Thread: carb installation kit: whos installed one?
    is smaller the cc, bigger the pp.
    farkas's Avatar
    7897
    Columbus, OH
    508
    yeah, im not liking that solution wit the box on the trees looks really cheey... if I get around to it i'll run a cable splitter and make my own under the bodywork for the TPS. the pcv will tell me how much its trying to adjust which will be a good tuning aid at throttle positions. I DO appreciate the info thoug.
    I agree.. it's a COMPLETE eyesore. I was thinking maybe running a longer throttle cable so that I could mount the "TPS assembly" on the frame somewhere, but I wouldn't be caught dead putting it on the risers like that.
    I'm sure it works fine without the TPS as I understand the ECU pulls a small amount of timing at idle to keep the fuel from loading up, but I'd really like to keep the function of the TPS. Certainly doesn't hurt to run carbs with "locked out" timing, but it definitely would help rideability to keep TPS functioning.
    m in sc likes this.
    MY plan is to use the oldstock TB hidden under the bodywork. I'll never use it so why not? hm. gopt me thinking. I also want it completely reversible so a bolt-on adapter for the carb should beprety easy to mae
    keit29's Avatar
    6117
    Aug 2015
    Columbus OH
    291
    How would this work? Would you run a throttle cable to both the TB and the carb? The stock TPS would be in the tB, correct? So you would still need to open and close both together.
    farkas's Avatar
    7897
    Columbus, OH
    508
    I'd really like to get the stock TPS off the TB and see how it functions... maybe we could find a clever way to retrofit
    4112
    Oct 2014
    Southeast GA
    1,458
    Well crap. I sold my TB and never thought about chopping it up to make a TPS adapter
    is bTuUsNaAnSuUtB
    Strokd_GE's Avatar
    54
    Central Florida
    3,067
    I personally was going to pick up a throttle cable for a dual carb setup, run 1 to the yoshi and the other to the TPS cam, I have enough old carb parts that I could fab up something small and tuck it into the frame under the tank
    Quote Originally Posted by keit29 View Post
    yup. 1 to 2 cable splitters are very common.
  1. Grom carb
    By moto in forum Grom Performance
    Last Post: 07-13-2016, 09:20 AM
  2. takegawa 124cc r+stage em head carb
    By kwstas11 in forum Grom Talk
    Last Post: 09-18-2015, 01:29 PM
  3. Carb on the dyno
    Last Post: 05-18-2015, 07:17 PM
  4. YOSHIMURA - New CARB kits (24/28mm) Webike
    By YYZGROM in forum Grom Performance
    Last Post: 11-06-2014, 01:57 PM
  5. whos bike is this?
    By str8h8n in forum Grom Talk
    Last Post: 09-24-2014, 01:26 PM
