Rear brake soft after riding for a while without using it
This is a discussion on Rear brake soft after riding for a while without using it within the Monkey Talk forums, part of the Honda Monkey 125 Forums category; Hi all, As the title of the thread states, all of a sudden I noticed the rear brake gets soft after riding for a while ...
Results 1 to 10 of 12
Thread: Rear brake soft after riding for a while without using it
    is Newly minted honda enthusiast
    31950
    23
    Hi all,
    As the title of the thread states, all of a sudden I noticed the rear brake gets soft after riding for a while without using it. By a while I mean going down a stretch of road for 3-5 miles or so and then I get to a light and have to brake. The pedal will have less resistance and it will travel more than usual, however the stopping power is not decreased. The bike has 1100 miles so far.
    After stopping and then using the rear brake shortly again, it will again have the "bite" that I expected.
    Things I've done to try to remedy the issue:
    1. Bled the rear brake line multiple times (It had one or two air bubbles, problem still occurred after all air was removed)
    2. Removed the rear brake pads and cleaned them and the brake components thoroughly (Had some brake dust but wasn't too bad)
    3. Checked and rechecked the rear wheel alignment (It was spot on)
    4. Checked the chain tension (It was within spec)
    5. Loosened and then torqued the rear axle nut back to spec
    Am I overthinking it and that's how the rear brake is? Could better pads help out?
    I know the rear brake on these bikes isn't spectacular or anything I just have never experienced anything like that on any of the motorcycles I've owned.
    Any feedback would be appreciated, thanks!
    is Big Ol' Pile of Dem Bones
    shush319's Avatar
    22114
    Jul 2017
    Daytona Beach, FL
    134
    Warped rotor possibly. If so, it'll push the pads and pistons back in the caliper while riding.
    mumdb1's Avatar
    31068
    Northern Colorado
    720
    44
    Quote Originally Posted by horheyortega View Post
    Hi all,
    Really interesting, I've actually noticed sort of the same thing on my yellow with just under 1,200 miles. I have to really push the rear brake almost to the ground to get stopping force, not that I really use the rear brake often, but I've definitely noticed it. Sometimes it's fine, the majority of the time it's almost worthless.
    2019 Honda Monkey in Banana Yellow
    - Yoshimura RS-3 SS/SS/TI Full System
    - TB Performance Cam
    - Cameron Jones Racing Custom ECU
    - MNNTHBX Mtake Intake System
    - MNNTHBX Seat Caps
    - MNNTHBX Classic Tail Plate Mount
    - Forged Aluminum Shifter
    - Adjustable Shorty Levers
    - H2C Rear Chrome Rack
    - Kenda Big Block Tires
    - 14t Front Sprocket
    - SpeedoDRD H9 Speed Calibrator
    31950
    23
    Quote Originally Posted by shush319 View Post
    Interesting, but the bike is so new? It can warp that quickly?
    31950
    23
    Quote Originally Posted by mumdb1 View Post
    No kidding? I'm starting to think that's how the rear brake is on this bike.
    3crows's Avatar
    31800
    Wichita, KS
    101
    I do not use the rear brake much. Have not noticed anything unusual. I tested the brakes out a few times to see what they can do. I am pretty sure I could skid the rear tire with enough effort and I suspect the relatively docile rear brake is intentional. I am no-ABS. The front brake seems more than adequate, I lifted the rear tire pretty easily with just a little forward weight shift and a good clamp on the front binder.
    If one were to upgrade the Monkey into an 80 MPH machine instead of the 50 MPH machine it is then one would want better binders and ABS front and rear.
    Swim, Bike, Run, Ride
    KBK0's Avatar
    31686
    France - Colmar
    116
    even with ABS, the rear brake is just fine for slowing down, not for emergency braking.
    the front brake is correct. coupled with ABS, Monkey stops easily. of course all this while respecting the speed limit which is, recently in France, at 80km/H, on our roads.
    shush319's Avatar
    22114
    Jul 2017
    Daytona Beach, FL
    134
    You did not mention what year the bike is. My 17 had a warped rotor when I got it from the original owner with 7k on the odometer, so yes it can happen. All it takes is to get bumped or hit by something hard enough to cause a slight bend. The pads do move much at all, so even the slightest bend will equate to a lot at the lever when the pads get pushed back.
    29712
    Aug 2018
    IL
    24
    It the Monkey, so less than a year old.
    31950
    23
    It's a 2019.
