Up Hill From a Dead Stop - Page 2
This is a discussion on Up Hill From a Dead Stop within the Monkey Talk forums, part of the Honda Monkey 125 Forums category; The Monkey, like the Grom, is also 15/34 stock....
Results 11 to 16 of 16
Like Tree6Likes
Thread: Up Hill From a Dead Stop
    31262
    Springfield, VA
    58
    KitKat's Avatar
    31564
    Los Angeles, CA
    29
    I may look into the sprocket idea.
    Thanks.
    30680
    VA
    97
    I'm 250lbs and while I'm not burning past cars on steep hills, I can maintain the speed limit (45ish) on even the longer hills. On the super steep hills, I try to plan for them. 95% of the hills I encounter are not an issue though.
    Stock gearing, exhaust, fuel controller, intake, and cam.
    30680
    VA
    97
    Quote Originally Posted by beatle View Post
    Difference being, the Monkey has higher profile tires making a tall gear ratio even worse.
    592
    Quote Originally Posted by Swampass View Post
    Ah, that accounts for the difference!
    I like the stock gearing. I can go 50 mph at 6,500 rpms.
    It's nice not to have to wind out the engine.
    2018 GROM: Modified for reliability and gas mileage.
    31262
    Springfield, VA
    58
    Ahh, I didn't realize the tire profile was different, but that makes sense. Stock Grom rear tire is 130/70 vs. 130/80 on the Monkey. That's a 5% effective difference in gearing. Dropping a tooth in the front lowers the gearing about 7%, so you're just about on par with a stock Grom's gearing. Bumping up a tooth or two in the rear may not be a bad idea since 14/34 is a pretty popular gearing on the Grom as well.
