Akrapovic Monkey Exhaust - Page 6
This is a discussion on Akrapovic Monkey Exhaust within the Monkey Talk forums, part of the Honda Monkey 125 Forums category; Originally Posted by bluestreak614 Has anyone tried installing the Akrapovic Slip-On to the stock head pipe? I've found that mine simply does not clamp tight ...
Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 51 to 60 of 69
Like Tree34Likes
Thread: Akrapovic Monkey Exhaust
  1. #51
    is Junior Member
    29978
    USA
    4800
    23
    Quote Originally Posted by bluestreak614 View Post
    I've found that mine simply does not clamp tight enough no matter what I've tried. Even with the C-clamp screw fully screwed in, I can easily remove it with one hand with little effort. Obviously there's a ton of leak. I have a hard time believing Akrapovic would mess things up that bad. Am I missing something?
    Akrapovic doesn't include a new exhaust gasket, which they should, because gaskets are a consumable and the original can crack or crumble when removing the original silencer. It can also get stuck in the silencer, even though it is meant to stay with the header/cat. They don't mention anything about this in their instructions linked here, and they don't include any pictures that show the gasket in place.
    Fortunately, Honda has been using the same gasket (Honda part number 18391-HB7-000) on dozens of models dating back to the 60's or 70's, so finding one cheap and in stock if yours is damaged shouldn't be a problem.
    https://www.partzilla.com/product/ho...ac31ce28aa41af
    Interestingly, Yoshimura's instructions explicitly say to remove the muffler gasket, and that it will not be used with their slip-on.
    bluestreak614 likes this.
  2. #52
    GdubluG's Avatar
    5091
    Apr 2015
    Phoenix, AZ
    78
    I know because Akrapovic has been installing resonators on all their super cross bike headers for some time now. Check out the bent cylinder resonator on this KTM header.
  3. #53
    GdubluG's Avatar
    5091
    Apr 2015
    Phoenix, AZ
    78
    Here is a close up shot of the small connection between then header and resonator. Exhaust and sound goes in, bounces around and changes the characteristics of the exhaust tone.
    Have a a little over 100 miles on it now. Engine runs much better after I installed PCV and WB2. The raspy note noticeable mainly on deceleration is now gone. Some kind of fuel controller is necessary after letting the motor breath.
    Attached Thumbnails Attached Thumbnails Akrapovic Monkey Exhaust-1e185c56-895d-43a1-a6b6-9e15749e12b3.jpeg
  5. #54
    556
    Quote Originally Posted by GdubluG View Post
    Thanks for the informative pic. The connection was very cleverly hidden.
    There HAS to be a physical opening into an exhaust system to enable a Helmholz resonator to operate.
    IXIL Dual Exhaust
    Kitaco Case Cover w/Oil Filter
    Takagawa High Volume Oil Pump
  6. #55
    686
    Wow really? For a resonator to work it has to be connected to the exhaust and not sitting on the shelf in your garage? What a revelation.
  7. #56
    556
    In Quibbly's eager rush to quibble...
    ...he neglected to read that the connection has to be into the exhaust, not just stuck onto the outside surface. That's the little tube hidden behind the mount connecting the two together.
    IXIL Dual Exhaust
  8. #57
    686
    tooter you're so full of shit it makes my brain hurt.
    your first post here was that it MUST be a heat shield. then upon hearing it's a resonance chamber you try to play the smart card.
    go fuck yourself you stupid old bastard.
    of course it's connected to the piping. what good would welding a chamber on to the exhaust be without connecting it into the piping?!
    i'm done with you. i wish there was a go fuck yourself you stupid old cunt block function, but sadly there isn't so im stuck with seeing your old fuck ramblings about your shitty bike economy in every goddamn post. whether it has any relevance whatsoever or not. fucking hell.
    the worthlessness of your opinions knows no bounds.
    skipr likes this.
  9. #58
    436
    Quote Originally Posted by tooter View Post
    You two need to get a room and stop cluttering up threads with the bullshit. I'm very new to this forum, but I've already seen this bickering a handful of times. It's getting old guys. You're both adults, right? So can't we just act like adults and ignore each other?
    I'm all for calling somebody out when they're wrong because spreading misinformation on a forum is so bad, but this isn't the way to do it.
  10. #59
    686
    He's a dumbass. He just wants to post pics of his shitty bikes, talk about his ecu on big bore threads, make self indulgent posts, and feed his confirmation bias. He's one of the lowest contributors I've ever come across.
    He's posted about his fuel economy in almost every thread on here. What an idiot.
    That's all...
    OpusNectar likes this.
  11. #60
    556
    Simply look at who always starts with nasty remarks... the Quibbler.
    IXIL Dual Exhaust
  1. Akrapovic exhaust vs Finbro exhaust
    By Notvindiesel in forum Grom Performance
    Last Post: 12-08-2015, 05:09 PM
  2. Akrapovic Grom Exhaust
    By Teets in forum Grom Performance
    Last Post: 10-28-2015, 10:19 AM
  3. Akrapovic GP exhaust spotted at Daytona!
    By GSXCBR1 in forum Grom Performance
    Last Post: 05-02-2014, 03:12 PM
  4. Finished my custom Akrapovic / Tyga exhaust
    By TerribleTarans in forum Grom Pictures/Videos
    Last Post: 04-01-2014, 08:37 PM
  5. *~^ space grom gets a custom Akrapovic exhaust ^~*
    By TerribleTarans in forum Grom Builds
    Last Post: 03-31-2014, 05:24 PM
monkey akrapovic
