Excessive moisture in oil - Page 2
This is a discussion on Excessive moisture in oil within the Grom Talk forums, part of the Honda Grom Forums category; Get a motorcycle cover and a good security Chain, all my motorcycles are covered up even if they are in a covered stall or car ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: Excessive moisture in oil
    4,884
    Get a motorcycle cover and a good security Chain, all my motorcycles are covered up even if they are in a covered stall or car port or garage, it keeps the dust and smog crude off the metal
    690
    66
    Smile Water in the oil
    Guys,
    When I started the 170cc kit, I did a complete review of the stock bike. I have a thermocouple mounted in my Grom's drain plug. I road the bike for 25 miles, all through the rolling hills around West Bend, WI, and I never got the oil sump temps over 204'F. Around town it never goes over about 175'F. Perfect oil temperatures are in the 220/240 range. I need to know, because I didn't want the 170 Grom to have oil temp problems. I wanted to see, if it needed a cooler. So, change your oil out more often. I tend to do it every 1000 miles on my other bikes. I would do the Grom at 500 miles, no filter, and ball bearing. The spinner is not really a filter, it's an extra flywheel, because it's a single.
    Brian S
    Grom1202 likes this.
    1678
    Nov 2013
    62
    Have you tied Seafoam. It's a gas and oil additive, I use it on all my bikes. Bikes run better and it's a fuel stabilizer too. You can buy it at any auto parts store.
    Remould's Avatar
    1383
    Sep 2013
    Surrey, UK.
    2600+
    168
    I have had the same problem on my MSX since day one.
    I change the oil every 500 miles and every ride is at least 30 minutes long (80% of that is WOT).
    The oil doesn't get contaminated, it just seems to be moisture in the crankcase..
    Sent from my HTC One using Tapatalk
    1533
    Oct 2013
    Portland, OR
    58
    Yeah I worded that poorly, my oil isn't contaminated either, just thick buildup around dipstick area.
    I guess just oil changes often to be safe, since it's so cheap.
    is braaap FMF!
    1010
    123
    Have you been draining this crankcase breather tube mentioned in the the owner's manual? I've had to drain mine several times but have nothing in the oil fortunately.
    1533
    Oct 2013
    Portland, OR
    58
    Quote Originally Posted by push bike View Post
    I'll give that a try, thanks for the suggestion!
    is an e-thug wannabe
    RaZed1's Avatar
    1799
    Nov 2013
    119
    I've noticed the little clear nub in the airbox (shown above) collects a bit of water, as it's supposed to. I notice it's full after a few rides, takes 10 seconds to slip it off and dump it. The oil in mine looks fine despite a bunch of rides in cold weather.
    1533
    Oct 2013
    Portland, OR
    58
    Looked at mine on the way to work and it does appear to be full. Gonna drain it when I get home, my fingers were to cold to try and get it off this morning.
    is Its an MSX! ;)
    Joe90's Avatar
    1770
    Nov 2013
    Portsmouth, U.K.
    1002
    116
    Mines got a little bit in the bottom, couldnt squeeze the circlip with my fingers though so ill have to leave it till i can get some needle nose pliers on the little sucker.
