Finally rebuilt the engine , diagnosis help please - Page 2
This is a discussion on Finally rebuilt the engine , diagnosis help please within the Grom Talk forums, part of the Honda Grom Forums category; Originally Posted by Old Goat Ninja Ethanol is all we have out here. My bikes ran fine after sitting that long. Out where? Here in ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 30
Thread: Finally rebuilt the engine , diagnosis help please
    4112
    Oct 2014
    Southeast GA
    1,444
    Quote Originally Posted by Old Goat Ninja View Post
    Out where? Here in the hot/humid Southeast you may have to rebuild carbs after 4 weeks of sitting with ethanol fuel. It'll suck up the humidity in the air and go bad really quickly.
    I don't know that fuel is his problem, but it really doesn't hurt or cost much to drain and put a bit of fresh in.
    Ridem32 likes this.
    7646
    greenville nc
    31
    Quote Originally Posted by Fox85 View Post
    thats definitely the case here in NC as well, that ethanol gas is hell on weedeaters, blowers, and everything else. it doesn't take long to go bad and gunk up a carb.
    19762
    31
    Stick to the basics first fuel air and spark check connections some of the simplest problems are over looked was the battery dead in the bike for 8 months also might want to do a pcm reset and throttle position learn
    Ridem32 likes this.
    is enjoying Grom Life.
    Old Goat Ninja's Avatar
    6817
    Jan 2016
    Manteca, Ca
    2,038
    California. We can't get gas without at least 10% ethanol in it.
    Instagram: Old_Goat_Ninja
    5,232
    Quote Originally Posted by HondaGrom+S2K View Post
    Hello everyone I finally rebuilt the grom engine that broke about 8 months ago. So after 13 hours I put everything back on the frame and reconnected all the wires lol I know that's way too long just to bolt stuff back. Well anyways I was super excited grabbed the key after finishing then went to start the bike and nothing :/ the bike will just crank but won't start. So I was hoping anyone could narrow down some possible scenarios of things I can do.
    So when I turn the key in the ignition I think I hear the fuel pump noise so it sounds like that's okay. But I did leave gas sitting in the tank for 8 months could this be an issue ?
    I checked the spark plug held it to the front end of the engine and saw sparks.
    I've checked the wires to make sure they are plugged in.
    It seems like it could be a simple thing but all input is appreciated thankyou
    Make sure your on/off switch is in the ON position.
    Check compression
    Check spark, remove spark plug, plug spark plug onto the wire, have plug near frame gnd and turn over engine and you should see spark jump across the gnd strap to the center of the plug. Make sure that you have some shaded area so you can see the spark. Make sure the spark plug wire is secured on the spark plug.
    take some WD-40 and remove the airbox or what ever and have the throttle body exposed, turn over the engine and spray WD-40 near the throttle body opening the engine should sputter or try to start, if it does then you have problem with the gas or fuel delivery system
    Make sure your Battery is fully charged.
    Oh when you check the compression, and you have none put the engine turns over, check the cam sprocket to make sure the tab is not broken or the sprocket is spinning correctly.
    good luck
    is Turbo Grom
    BiG Chris's Avatar
    746
    BAY AREA
    1,019
    If if you have spark then check if your getting fuel, you can take the injector off the manifold and with it still plugged in crank the motor over and use a red shop towel while holding it and it should spray and its easy to see on the towel. So now if you have fuel and spark you need to check timing and valve lash. Let me know if that works first if not let me know.
    BCGarage - I offer services for your grom
    NOR-CAL EMPIRE
    KIWI2RACING
    STEADY GARAGE
    is full throttle and going
    nowhere
    Davyboy's Avatar
    4724
    If I were doing an engine rebuild n ran into a no start after I reinstalled it the first things I would check is making sure all the wiring is correct then the basic's check for spark n the timing is correct etc.
    7606
    CA
    184
    It could be a lot of things. If you take out the spark plug and put your thumb firmly on the spark plug hole while cranking does it blow your thumb off? If not you don't have enough compression to run, check your valve timing.
    If you took your flywheel off, did you reinstall the key or make sure the flywheel was lined up with the key? Seen that happen before. Your ignition and fuel timing will be too far off to run if that happens.
    Quote Originally Posted by gromaste View Post
    Check compression
    good luck
    Quote Originally Posted by BiG Chris View Post
    Quote Originally Posted by Davyboy View Post
    Thanks for all the input guys I appreciate it so I brought it back to the shop and I guess the issue was after taking off the top end it needed an intake and exhaust valve seal thing. That's what was causing low to no compression. So hopefully once the parts arrive that's all it needs. Can't wait to ride the grom lol
    Ridem32 likes this.
    19513
    58
    A valve stem seal will not cause low compression. But will cause it to let oil by it causing it to burn oil and smoke. If valves are adjusted correctly then I would check my rings if compression is low
    Davyboy likes this.
    19513
    58
    Are do you mean the valve seats. If valves are not seating then they need to be lapped. Not seating could cause low compression
  1. Replies: 12
    Last Post: 08-26-2016, 08:47 AM
  2. Replies: 12
    Last Post: 12-10-2015, 11:32 AM
  3. Replies: 0
    Last Post: 10-19-2014, 10:37 PM
  4. It's finally here!!!!
    By Kstequila in forum Grom Pictures/Videos
    Last Post: 02-24-2014, 04:30 PM
  5. Finally! It is here!
    By rkwfxd in forum Off-Topic
    Last Post: 08-01-2013, 11:31 AM
