Ecu problems?
Ecu problems?
This is a discussion on Ecu problems? within the Grom Talk forums, part of the Honda Grom Forums category; Has anyone heard of any ecus going bad? I dropped my bike off to the dealer for the fuel pump recall a few days ago. ...
Results 1 to 6 of 6
Thread: Ecu problems?
    H2bjay's Avatar
    7073
    Mar 2016
    12
    Ecu problems?
    Has anyone heard of any ecus going bad? I dropped my bike off to the dealer for the fuel pump recall a few days ago. When I went to pick it up I started it to let it warm up while I grabbed my helmet from the car n put the paper work away. So as I was standing there it just died out n I found it funny because never once has it don't that! So I walk over turn the key off n back on then start cranking away it won't start at all I pulled it back in the shop so they can look thru it but couldn't find nothing. They didn't have a replacement ecu in stock so I called my buddy to bring up his ecu to try it n bam started with an issue first push of the button. They Said they have never seen it happen but it did. So said he'll call Honda on Tuesday to get me a replacement. Has any one heard if issues like this the bike has maybe 2200 miles and has never given me any issues sleeps inside the house aswell lol
    5,427
    I'm sure that they reset the ECM, cleared DTC, and reset TPS.
    I know on my fuel pump recall they did all that. Ask them "the shop" if they did that, all you can do it yourself. There is a posting I did and other's have done on how to do the ECM clear, reset, TPS reset and high altitude adjustment
    good luck
    H2bjay's Avatar
    7073
    Mar 2016
    12
    good luck
    We didn't reset anything just plugged in my buddy's ecm n it started then plugged mine back in it didn't start so just gonna get a new one lol
    is bbk woohoo!
    humilde_s13's Avatar
    1400
    Sep 2013
    Virginia
    13500
    609
    I have oem ecu if you are interested
    #Aracer rc mini plus 2 #Takegawa 181cc #finbro 125cc head #yoshimura cam #koso 34mm tb #finbro 6 hole injector #brocks exhaust
    Takegawa 181cc
    Finbro head
    Koso 34mm
    Yoshimura cam
    H2bjay's Avatar
    7073
    Mar 2016
    12
    Quote Originally Posted by humilde_s13 View Post
    Thanks bit I won't be paying for one seeing as I didn't even leave the honda dealers lot lol
    H2bjay's Avatar
    7073
    Mar 2016
    12
    Dealer called I'll have a new ecm beginning of the week they got it covered by honda!
  1. WB2 problems
    By Fiercetimbo17 in forum Grom Talk
    Last Post: 03-18-2017, 09:50 PM
  2. Can the Finbro ECU be reset like the stock ECU?
    By jtxr in forum Grom Performance
    Last Post: 09-29-2016, 04:00 PM
  3. Any major problems?
    By AJ Nin in forum Grom Reviews, Rides and Impressions
    Last Post: 01-14-2016, 07:24 AM
  4. Clutch problems
    By gromrevver in forum Grom Performance
    Last Post: 12-24-2015, 11:52 AM
  5. M4 exhaust problems?
    By Hater in forum Grom Talk
    Last Post: 02-08-2014, 11:44 AM
