My Takegawa 181-4v build started today, tearing down my BrianS 170 - Page 2
This is a discussion on My Takegawa 181-4v build started today, tearing down my BrianS 170 within the Grom Talk forums, part of the Honda Grom Forums category; Nah, I'm over in Texas, got our own testing grounds....
Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 134
Like Tree40Likes
Thread: My Takegawa 181-4v build started today, tearing down my BrianS 170
    GlockPointer's Avatar
    3606
    315
    5,427
    Quote Originally Posted by GlockPointer View Post
    Texas get pretty hot, hope you have a good external oil cooler and are you using full synthetic oil. I just switched over to AMSOIL 10/40 for the first time on my Finbro 183 grom which has over 6K miles on the ODM. Seems to help out since I see 230F at the high end now after riding the freeway around here at WOT.
    Hey ride safe
    99
    I am enjoying this build thread. Thank you for posting -- especially the photos.
    .....Still figuring out the mounting setup for my external oil cooler.....
    I will be very interested in what you decide. I am also trying to decide where to mount an external oil-cooler -- either up high (and ditch the airbox) or lower on the cylinder head. I see pros ad cons with either approach.
    5,427
    I thinking up high using those two open holes on the main frame as a support with some type of frame bracket being secured by those holes and the fame/long rod or something to that coming down and using the bracket mount that came with my Chinese made 5 channel oil cooler. Lots of neat ideas in my head. Oh and I will still have my open mouth modified OEM airbox, right now I will trim back the cut out front piece that holds the air filter in place because with my future design of the mounting bracket going full left the oil cooler hits the front left tube just a bit.
    have to trim the lip about 1/4 to 1/2" back. Notice the over hang of the frame, that part needs to be cut out and that should be enough space for the external oil cooler mounting. By cutting out the extra lip area it will remove one of the drain plug with the black nipple/plug. I could go from the airbox 2 bolt nut and make a frame coming our like what HR sales or I can try to build one my way.
    5,427
    Decided to clean the engine case since I'm still waiting for my 5 speed transmission. I cleaned around the counter sprocket area which was caked with chain lube. I did notice something that was wrong with the cam chain tensioner arm.
    wipe down the area round the arm and found lots of metal shavings so when I crack open the case everything will have to be wiped down and also wiped over with a magnet to hopefully pickup any metal shavings.
    cam chain tensioner arm touch down with gear, possible problem due to worn down wheel or my spacer unit that BrianS made for my kit way back in 2014.
    1,551
    thats due to the worn down wheel allowing the rod to come further up.
    2,806
    yup. bummer. fucking rubber wheels
    5,427
    Federal Express shows up and I thought it was a April Fools joke when a package arrived, and now I have to split the case.
    Thanks HR, my Takegawa 5 speed transmission and Kitaco cam chain arm arrived. Time to modify the pin on the Kitaco arm so my metal sprocket will mount correctly.
    is not proof-reading much
    warubouzu's Avatar
    6274
    Sep 2015
    170
    There was a post on FB showning one of the metal wheel style cam chain rollers having failed. Monkey Father later posted a comment about it saying the metal wheel carries too much inertia and resulted in the failure (toothed metal wheel seperated from the bearing center it spins on.) Monkey Father also stated that the cam chain roller wheel needs to be considered anconsumable part that simply needs to be replaced more often due to the stresses of BBK and/or 4v heads. That said, the new Kitaco and Takegawa cam chain rollers looked much improved over the FinBro version. Being that the wheels are easily replaceable, they have a wider foot for the tensioner button to ride against as well as the upgraded button itself.
    ALanS likes this.
    FinBro 235 4v #001 - Daily Driven.
    warubouzu's Avatar
    6274
    Sep 2015
    170
  1. Replies: 2
    Last Post: 10-04-2016, 06:17 PM
  2. Koso or Brians 170?
    By Macloven in forum Grom Talk
    Last Post: 04-03-2016, 11:12 AM
  3. Replies: 10
    Last Post: 08-10-2015, 08:43 AM
  4. Replies: 18
    Last Post: 08-04-2015, 11:35 AM
  5. Replies: 17
    Last Post: 10-27-2014, 06:55 PM
gear as transmission 30 takegawa
