SF Finbro cold start fix? - Page 3
This is a discussion on SF Finbro cold start fix? within the Grom Talk forums, part of the Honda Grom Forums category; This ones a little better!...
Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 21 to 30 of 39
Like Tree7Likes
Thread: SF Finbro cold start fix?
    12674
    Nov 2016
    21
    turpinator likes this.
    jonesn's Avatar
    5717
    Missouri
    10k+
    55
    I've been running the PSD cold start fix on several different bikes this winter. Soon to be an SF as well, just waiting on the harness. So far the cold start fix has been great. The bikes I install a koso camshaft on typically NEED the cold start fix. The bikes I just do intake/exhaust on I haven't had the need to use the harness. It will help don't get me wrong, but typically a little fine tuning of the air screw and the idle screw (buy a thumb screw idle from steady garage, or F4i cable and cut it down) goes a long way.
    2015 Honda Grom, 12.6k miles (12-2-16) KOSO 170 2v, K- filter, K-connecting tubes, K-Camshaft, Finbro ECU, DG V2 Low Mount, Kitaco Cover, Takegawa High Flow Oil Pump, 10 hole injector, K- 34mm Throttle Body, K- 34-30.5mm intake manifold, PSD Subcage, PSD dual caliper bracket, Magura HC1 13mm handbrake, P34 brembo caliper, all stainless lines (goodridge), KX high pro taper fat bars + much more.
    http://www.hondagrom.net/forums/27-g...ace-build.html
    1,927
    Quote Originally Posted by Kbaron91 View Post
    sauce? Do you have the rest of the service manual too?
    12674
    Nov 2016
    21
    Quote Originally Posted by jonesn View Post
    See I wondered and asked Franco Rodriguez of finbro about adjusting the screws and he said it was unnecessary 🤔
    2,650
    ..thats the difference between a parts slinger and an actual tuner. Just saying.
    1,436
    still horribly low res :-/
    12674
    Nov 2016
    21
    Unfortunately I don't. This got sent to me by someone on fb
    12674
    Nov 2016
    21
    I've been in contact with several people about this and I'll be getting the zero stunts harness through psd. When I receive it I'll get it all worked out and let everyone know the results. Btw psd and Zero have been awesome to talk to and have been helping me out with the matter. All the input and help from everyone here is much appreciated as well!
    1,436
    like stated all zero stunts did was copy my design. Im 99% sure the injector wire pin is the same on the SF but couldnt tell you for sure without a diagram thats legible.
    1,927
    Injector wire is 16 on both.
  1. Finbro ECU and Cold Starting
    By a_morti in forum Grom Talk
    Last Post: 01-10-2017, 03:49 PM
  2. Replies: 5
    Last Post: 08-01-2016, 02:33 PM
  3. Finbro cold starting fix!
    By nd4spdbh in forum Grom How-To's and Guides
    Last Post: 05-22-2016, 02:56 PM
  4. Grom sputters on cold start?
    By Jpiepes in forum Grom Talk
    Last Post: 05-06-2016, 12:20 PM
grom cold start issues
