5 row oil cooler vs 3 row
This is a discussion on 5 row oil cooler vs 3 row within the HardRacing Performance forums, part of the Vendors category; I was wondering if the 5 row cooler would fit where the 3 row cooler with the high mount in between where the fender brace ...
Results 1 to 10 of 17
Thread: 5 row oil cooler vs 3 row
    lip
    lip is offline
    is The F-ing Man
    9641
    Aug 2016
    ocean city nj
    36
    I was wondering if the 5 row cooler would fit where the 3 row cooler with the high mount in between where the fender brace would go...
    gromlin_no's Avatar
    8641
    Aug 2016
    Oslo, Norway
    87
    It would. Go for it and be cool, brah!
    Sent from my Nexus 5X using Tapatalk
    estallings15 likes this.
    is enjoying Grom Life.
    Old Goat Ninja's Avatar
    6817
    Jan 2016
    Manteca, Ca
    2,038
    Quote Originally Posted by gromlin_no View Post
    What you did there, I see it.
    gromlin_no and estallings15 like this.
    Instagram: Old_Goat_Ninja
    Pigman's Avatar
    3581
    726
    Cool as ICE....
    1,984
    I believe the 3 row has tapped mount holes that are horizontal, while the 5 row has bolts that go vertically. Check the mount to ensure it has the correct orientation.
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    Charlotte, NC OHLINS_MASTER_DEALER
    3,556
    Quote Originally Posted by lip View Post
    Assuming you are referring to the optional "Frame Bracket" Mount ?
    If so...... it will fit same as 3 row.. but, it hangs down a little lower, so you may need to trim the inner panels a little, or set them a little farther apart to make room.
    lip likes this.
    HardRacing.com - 704-799-2192
    See our complete >> GROM PARTS CATALOG <<
    Check out our Youtube Channel for Lots of Great Parts Installation Videos >> GROM CHANNEL<<
    Ohlins Premier Dealer, Great Prices, Tech.Support, Full Staff of Sales Reps, Fast WORLD WIDE Shipping,
    Large Inventory and Excellent Customer Service.
    Celebrating our 17th year in business
    6752
    1
    Quote Originally Posted by HardRacing View Post
    HR: In the other thread about the Kitaco 3 vs 5 row oil cooler from 2015 you stated that in order to run the frame mount for the oil cooler AND the chimera intake, the mount had to be modified. You sent the information to another member in a PM, think you could share that information here? Also, do you have to modify the frame mount regardless of whether you choose the 3 row or 5 row? Thanks guys.
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,556
    Quote Originally Posted by Adudeguy View Post
    That is correct.
    You have to trim the wings off, right next to the U Bracket. Since they are no longer used.
    Very simply.
    1,984
    Pics of bracket and oil cooler with the chimera intake here:5 Row Oil Cooler, need some opinions ??
    In my opinion, its basically removing the advantage of that mount to basically every other mount out there... its ability to hold the body panels in place, just like the airbox does, and the fairing rod you can get with the chimera attempts to prevent. So if youre going to run a chimera with the oil cooler way up there, why not mount it a different way?
    Also, these brackets could easily be modified/retooled (possibly without even changing the flat configuration), by simply putting a very large radiused, partial bend/dip, into the portion that interferes with the chimera's filter.
    Supporting Vendor
    HardRacing's Avatar
    1614
    Oct 2013
    3,556
    The main reason for this Frame bracket is to relocate the cooler up and off the valve tappets.
    This allows easy access to your valve tappet covers to do valve lash check.
    it also clears up room for any other work on the motor.
    It also removes all the stress from that cooler hanging off the head.
    The Chimera fairing braces does a perfect job of holding the fairings together.
  1. 5 Row Oil Cooler, need some opinions ??
    By HardRacing in forum Grom Talk
    Last Post: 12-13-2016, 07:29 AM
  2. Composimo 3 Row LED Bars
    By coltons09 in forum Parts for Sale / Wanted
    Last Post: 01-04-2016, 10:09 PM
  3. Wtb: 2 or 3 row led headlight
    By whbwrestling in forum Parts for Sale / Wanted
    Last Post: 07-20-2015, 09:43 AM
  4. Annual Race Night on the Row | Monterey, CA
    By pwr2wh8 in forum Grom Events
    Last Post: 07-14-2014, 06:21 PM
  5. Double Row LED Headlight
    By Shoebacca78 in forum Grom Talk
    Last Post: 12-06-2013, 01:50 PM
composimo lower fairing
