BBK Time 164cc/Build thread
This is a discussion on BBK Time 164cc/Build thread within the Grom Builds forums, part of the Honda Grom Forums category; Just got a smoking deal on a Kitaco 164cc kit, the only crappy part is riding season is almost over here. So I won't get ...
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 47
Like Tree20Likes
Thread: BBK Time 164cc/Build thread
    8009
    ND
    700
    143
    Just got a smoking deal on a Kitaco 164cc kit, the only crappy part is riding season is almost over here. So I won't get to ride the BBK until next year . I will throw the cam in though, if it gets here in time!
    Kit comes with:
    60mm cylinder
    piston/rings
    gaskets
    type 1 cam shaft (I wanted more mid range power)
    High flow injector (how much? I dont know lol)
    wristpin and circlips
    Current Grom:
    OPMID temp Gauge
    Zoom Exhaust
    Integrated Tail light and LED license plate bolts
    Flush blinkers
    Renthal Bars
    Ebay levers and bar ends
    Wider and lower mirrors
    In the mail/waiting to go on:
    Ohlins shock
    Chinese lower cowl
    ND4s front shock mod
    SLC wideband
    API stand alone ECU w/ cable (selling because I do not have a computer that has windows, PM if you want it)
    Going to order over the winter:
    Finbro ECU
    Clutch plate/springs
    New Oil pump
    Ebay oil cooler
    Luggage rack
    After the BBK I think I will be done dumping money into this thing! but I said that after each item I have bought.
    I don't take to many pictures of the bike but I will start when I do the BBK.
    BBK Time 164cc/Build thread-exhaust.jpg
    Attached Thumbnails Attached Thumbnails BBK Time 164cc/Build thread-fullsizerender.jpg
    estallings15 and BuenosNoches like this.
    is Loving the Big Bore life!
    estallings15's Avatar
    7251
    3100
    1,264
    Congrats on the Kitaco 164. Great mix of power and reliability. Looking forward to seeing your progress.
    lordstanley likes this.
    Koso 170
    Finbro Big Valve head & TB
    Takegawa S-Stage Cam
    PCV/WB2
    1,434
    Pretty much my setup.
    Once i figured out the mod for the finbro ecu and cold starting, the thing has been great. (see my signature below for the link)
    About the ONLY thing id have left to do to make it super reliable is a different cam chain tensioner wheel, but 500 miles and no rubber shavings yet.
    While your in there doing the clutch springs, do yourself a favor, replace the thrust washer, clutch collar, and throwout bearing... 10 bucks in parts that are prone to wearing out (my clutch collar had glazed over and would squeal)
    8009
    ND
    700
    143
    I was originally going to go with the Takegawa 143 until I found the 164cc for such a good deal, plus I get to add an oil cooler without the Kitaco clutch cover! Also have the Finbro cold fix saved!
    For the cam tensioner wheel, what do you recommend? I was looking at FinBro Cam Chain Tensioner Roller Upgrade - Finbrogarage
    Did you replace the thrust washer, clutch collar, and throwout bearing with OEM parts?
    8009
    ND
    700
    143
    Does anyone know what injector the Kitaco kit comes with? Will it be OK with the Finbro?
    1,434
    Quote Originally Posted by lordstanley View Post
    No idea what injector comes with the 164 light bore kit and cam package (i bought the type 1 cam and ran that in my 125cc bore for awhile then purchased the 164 kit without the cam). Definitely report back on that injector! If its the PCX150 injector its going to run too lean with the finbro ecu and the 164... I had to switch to the Finbro supplied "6 hole Keihin" injector which is off the CBR150R
    OEM parts for the clutch collar, thrust washer and TOB.
    I have not upgraded the cam chain tensioner wheel, but i have swapped out the stock rubber button on the top of the cam chain tensioner push rod with a nylon bolt that i filed down round. I did know Finbro usa had those arms... im tempted to put one in now as that is my last "unreliable" part i have in my bbk setup.
    Check out the build thread for some of the details
    ND4's Function over Form Build
    8009
    ND
    700
    143
    The injector is the Keihin EF04-NNJ unit, but I couldn't find anything online about it. Will just have to wait for it to get here.
    Edit** Here is the injector, looks like they recommend it in the 181cc. Hopefully it will work with the finbro and 164
    http://www.minimobracing.com/store/p...duct_info.html
    8009
    ND
    700
    143
    So I have been doing some research about letting the grom breath with the BBK and have a couple questions. Will a slight port/polish on the stock throttle body be enough or will the Koso TB and IT manifold be worth it? I have read that the Koso TB is kind of pointless with stock valves?
    7251
    3100
    1,264
    BrianS tested the stock TB and said it's good to 170cc, I believe. The important part is the porting job on your head and having enough flow on the exhaust. Koso TB would be overkill, and particularly pointless without matching the intake port.
    Cisco swears by it, though
    Koso 170
    PCV/WB2
    1,922
    Quote Originally Posted by estallings15 View Post
    Stock tbody is plenty big. Sure, you can replace it for a larger one and see some improvements, but you would see the best improvement from larger valves and a ported head, as thats the major restriction.
    estallings15 and lordstanley like this.
  1. Yumanishi Ultimate BBK 164cc $450
    By griff in forum Parts for Sale / Wanted
    Last Post: 01-12-2016, 10:25 PM
  2. Yoshimura 164cc Ultimate BBK?
    By justinschmidt1 in forum Grom Performance
    Last Post: 08-27-2015, 10:07 AM
  3. Well I Fuked up BIG TIME... 183 Finbro build...
    By KoreaMSX in forum Grom Talk
    Last Post: 06-05-2015, 07:44 PM
  4. [Build] Tina's Build Thread
    By dylan_baker23 in forum Grom Builds
    Last Post: 05-03-2014, 05:42 AM
  5. [Build] Pat's build thread
    By Eurobeaner in forum Grom Builds
    Last Post: 09-12-2013, 09:52 PM
kitaco 164cc grom
kitaco grom tensioner
nascar cylinder head porting
