aftermarket cams and valve float with stock springs
This is a discussion on aftermarket cams and valve float with stock springs within the Grom Performance forums, part of the Honda Grom Garage category; Has anyone actually gotten valve float after installing an aftermarket cam with the stock valve springs? After searching all I am seeing is a lot ...
Results 1 to 10 of 15
Thread: aftermarket cams and valve float with stock springs
    7369
    96
    Has anyone actually gotten valve float after installing an aftermarket cam with the stock valve springs? After searching all I am seeing is a lot of what ifs and could happens, the only incident I've come across is suposedly dcr got some coil bind from their cam then came out with their own set of valve springs.
    5,134
    If you are reving at a constant 7-9K rpm maybe it would be a good idea to get the DCR duel valve spring a great $79 investment
    http://danielcrowerracing.com/i-1756...t-2014-17.html
    7369
    96
    Im running it near or at red line 80% of the time the bike is running, it lives at the kart track and I have had no float issues yet.
    But bigger cam going in and the finbro ecm allows for that 12.5k rev limit, I'm sure I'm pushing it especially with that 12.5k limiter, just wanting to see if anyone has hit that ceilin ceiling yet
    rob78's Avatar
    1305
    Sep 2013
    68
    Quote Originally Posted by Aj510 View Post
    What cam are you running now, what are you changing to and why? Are you currently using the finbro ecm
    TMGP Sprint #78
    Endurance Team "I Just Wanna Ride" #104
    http://texasminigp.com/index.html
    Half the Size Twice the Fun
    1,498
    I ran stock valve springs with a kitaco type 1 cam for awhile with the finbro ecu..... it saw 12.5k redline a few times. Im sure there was some float with the stock springs but never enough to touch piston.
    Just do what i did. when you have your head off next spend the 10 bucks, yes all of 10 bucks, for some finbro heavy duty valve springs and never worry about it again.
    is A Meat Popsicle
    Ronbang's Avatar
    2953
    May 2014
    NJ
    210
    620
    Finbro ecm allows for 12.5k rpms...but your never gonna get to 12.5k rpms. Your gonna get to like 10,10.5,11 maybe maybe that's it. That's straight from finbro I asked them about this question...they said stock springs are fine they informed me that their test bike wasnt getting that high revs...so im thinking it's fine
    is enjoying Grom Life.
    Old Goat Ninja's Avatar
    6817
    Jan 2016
    Manteca, Ca
    1,973
    Quote Originally Posted by Ronbang View Post
    That's only true in 4th. Any other gear can get to 12.5 no problem.
    Instagram: Old_Goat_Ninja
    obijuanito's Avatar
    4704
    243
    At the grom cup, we run stock springs and rev it to 10-11k and never had a issue with valves floating
    Enviat des del meu LG-V500 usant Tapatalk
    7369
    96
    Quote Originally Posted by obijuanito View Post
    That's good to hear.
    Motor is completely stock but between this week and next I'll be putting in the finbro ecm, pcx150 injector, finbro 125cc cam and finbro flat top 125cc piston.
    Between the ecm and cam is what I was worried about, I'm running -1/+2 sprockets so it will rev out pretty far
    1,498
    if you are going that far, do yourself a favor, buy the 125cc super head from finbro. Everything that i have done to my bike, the stock head with stock sized valves is 100% the bottle neck. Even on stock bore. And im fairly certain that the superhead comes with stiffer valve springs already installed. so win win.
    If you are going to do it... do it right the first time. I really wish i had done a bigger valved head with my 164cc bbk.
  1. Aftermarket clutch springs..???
    By Grom1202 in forum Grom Talk
    Last Post: 11-20-2016, 09:30 PM
  2. Upgraded valve springs?
    By nd4spdbh in forum Grom Performance
    Last Post: 04-17-2016, 07:08 PM
  3. Grom aftermarket cams??
    By gromrider24 in forum Grom Performance
    Last Post: 01-29-2016, 09:44 AM
  4. Stock valve springs rev limit
    Last Post: 04-19-2014, 07:23 PM
  5. Replies: 51
    Last Post: 03-28-2014, 03:05 PM
