aftermarket cams and valve float with stock springs - Page 2
This is a discussion on aftermarket cams and valve float with stock springs within the Grom Performance forums, part of the Honda Grom Garage category; Originally Posted by Mike884 I didn't take my grom much past maybe 10.5 and there was definitely some float with the DCR cam and the ...
Results 11 to 15 of 15
Thread: aftermarket cams and valve float with stock springs
    5,408
    Quote Originally Posted by Mike884 View Post
    I didn't take my grom much past maybe 10.5 and there was definitely some float with the DCR cam and the intake valve actually Made slight contact with the stock piston. Not hard enough to cause a huge issue but it's indented.Attachment 55833
    after seeing the piston I installed the finbro springs. Hopefully that solves the issue
    I had the HD Finbro valve springs on my 183 finbro head and I replaced it with the DCR duel springs and I haven't any problems at all.
    is adventuring one bike at a
    time.
    AzizaVFR's Avatar
    7236
    Red Rock, AZ
    134
    Like a few others replied above, I have the DCR cam with stock springs and my bike is either ridden on the local kart tracks or in the dirt. The only float the motor has to deal with is braking harder into the corners, floating the rear wheel prior to the apex, and over tabletop jumps. With the stock compression you have more any adequate clearance between valve face and piston top for 99.9% of all riding situations. Induce less worry about the springs and create more fun through the copious application of throttle and lean angles.
    2002 TTR-125 (Wife's)
    2006 KTM 625 SMC (Evil Mistress)
    2010 CRF-70 clone (Daughter's)
    2015 Grom x 2 (Hers and His)
    2016 BMW R1200GS (Daddy Bike)
    "Six bikes are our limit." -Unicorn Wife
    7369
    100
    Thanks, but from my understanding the springs Are not going to stop your piston contacting the valve. At high rpms and bigger lift ratios some springs have a hard time keeping up with the revolutions of the cam and not allowing the valve to open and close completely causing a "floating" valve. Odds are you are still seeing contact with your piston.
    is bTuUsNaAnSuUtB
    Strokd_GE's Avatar
    54
    Central Florida
    2,979
    Quote Originally Posted by Aj510 View Post
    Stiffer springs are going to raise the operating rpm at which they can successfully close the valve and not float. Stiffer the spring, the more resistance being transferred to the cam lobe insuring it follows shape and doesn't get left behind when after peak lift
    2,805
    thats the whole point of stiffer springs is to avoid that contact of valve to piston. whether its from an aggressive camshaft or adding boost, or both.
  1. Aftermarket clutch springs..???
    By Grom1202 in forum Grom Talk
    Last Post: 11-20-2016, 09:30 PM
  2. Upgraded valve springs?
    By nd4spdbh in forum Grom Performance
    Last Post: 04-17-2016, 07:08 PM
  3. Grom aftermarket cams??
    By gromrider24 in forum Grom Performance
    Last Post: 01-29-2016, 09:44 AM
  4. Stock valve springs rev limit
    Last Post: 04-19-2014, 07:23 PM
  5. Replies: 51
    Last Post: 03-28-2014, 03:05 PM
