How are transmission ratios calculated... - Page 2
This is a discussion on How are transmission ratios calculated... within the Grom Performance forums, part of the Honda Grom Garage category; Thank you Juls! Im happy with the stock 0.923 gearing it can get me decent speed on a flat road i just hate the pull ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 24
Thread: How are transmission ratios calculated...
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    Thank you Juls! Im happy with the stock 0.923 gearing it can get me decent speed on a flat road i just hate the pull in stock gearing 1 through to 3. The temperature info is great! Riding with 14t front sprocket im only at 50% throttle to get decent acceleration even up hills so temp info makes sense.
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    has anyone used the takegawa 5 speed with a stock engine ? is the tall 1st really hard to get the bike moving? especially on hill starts?
    I love my grom
    7813
    168
    It doesn't make much difference, 2.5:1 or 2.33:1 makes little difference. That bigger jump up top is huge, but down low it doesn't make a big difference.
    there is plenty of room in the casings for the 5 gears in terms of width, all the takegawa cogs are the same width or wider than stock so as strong or stronger than stock. The stock gearbox is a bunch of crappy casts that waste heaps of space.
    The issue is the space between the two racks of gears can't be changed so your limited what you can do in terms of ratios, hence takegawa loses some down low to keep the stock final and kitaco loses some final to gain a bit down low.
    The reason your limited in gear size (outside diameter) is the stock gearbox has its dogs hanging out the side of each gear, to squeeze a 5 speed in some of the dogs need to be inside gears, so your limited as to how small a gear you can use as you need to have an engagement dog inside the gear as well. Hence the limitations in ratio in the 5 speed boxes.
    If you look at the kitaco gearbox you see what looks like weight saving holes in the gears, well actually they are for the dog drive to engage in. Takegawa only machines out the holes as far as necessary to help keep strength.
    which box is better? No idea. Takegawa works for me, kitaco was $150 more on webike the day I bought mine.
    Old Goat Ninja likes this.
    Waz-r's Avatar
    8954
    Aug 2016
    Newcastle
    50km
    114
    Quote Originally Posted by Juls View Post
    Wealth of information.. i see the kitaco has the same 1st final drive as the standard trans . i was wondering about the diameters and even thinking about getting 2 custom made cogs to get 1st gear to 2.67 fd which would basicallly make it like having the same drive as a 14t sprocket on the standard box but having the final drive of the standard box 0.923 with a 15t sprocket... i guess this is never going to work because of diameters ... so do you have the Takegawa on a 125 motor or a bbk?
    I love my grom
    7813
    168
    Light bore 164, no head or throttle body mods yet.
    2,562
    custom gears being made are extremely expensive to be done right. I really wouldn't worry much about 1st gear being a problem. its 3rd-4th (or 5th) that really matters especially the spread between them, unless you are on the drag strip looking for a good launch
    1,387
    ONLY way id ever be OK with a first gear that is taller than stock is if 5th was taller as well... that away one could reduce the final drive gearing and get back to a stock first gear ratio. IMO stock the grom has way too tall of a first gear... but thats me and my weird pseudo dual sport nature of my grom.
    TheMajekalBum's Avatar
    6538
    Oct 2015
    Longmont, Co
    228
    100% agree, first is too tall stock. Even with a 14t it's a bit taller than I'd like for the kind of riding I do.
    2,562
    really? with a 16/36 mine pulls like a freight train in 1st now and lifts under power . I can actually start in 2nd if need be. and I weigh about 195-200 lbs.
    1,387
    well yeah you are running a BBK no?
    I have since switched back to almost stock gearing with my 164cc for around town. But sometimes i still feel its too tall, too much clutch slipping needs to take place. I cant just let the clutch out slowly and idle in gear if its much more than flat.
    But thats asking alot of a lil 164cc motor. haha
  1. TRANSMISSION Noise.
    By Grom1202 in forum Grom Talk
    Last Post: 07-19-2016, 12:30 PM
  2. 5 speed transmission
    By jay851 in forum Grom Performance
    Last Post: 05-19-2016, 07:03 AM
  3. 5 speed transmission
    By Chad in forum Grom Talk
    Last Post: 12-13-2015, 09:59 PM
  4. Factory air fuel ratios tested. . .
    By YayGrom in forum Grom Performance
    Last Post: 10-17-2015, 12:57 PM
  5. 5 speed transmission?
    By VinnyC. in forum Grom Talk
    Last Post: 01-29-2015, 04:09 AM
