Headlight bulb H4 upgrade - Page 3
This is a discussion on Headlight bulb H4 upgrade within the Grom Gear and Accessories forums, part of the Honda Grom Garage category; Install was easy. Only two tools reguired. (A, I believe, 5mm Allen and a small Phillips head screw driver) first remove 4 bolts on boomerangs. ...
Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 51
Like Tree28Likes
Thread: Headlight bulb H4 upgrade
    is KCCO
    hicksy712's Avatar
    1461
    Oct 2013
    Mt. Juliet TN
    201
    Spread housing and remove from bracket.
    Unplug harness. Simply pulls off
    Remove rubber gasket/cover. Just pulls off as well.
    Undo spring clip from stay and loosen hold-down screw if needed.
    Remove bulb. (Don't touch glass) set aside for rainy day.
    elizerr and mecevans like this.
    is KCCO
    hicksy712's Avatar
    1461
    Oct 2013
    Mt. Juliet TN
    201
    Bulb comparison. No noticeable difference. Even the mentioned prongs are very similar. I did nothing modification wise. Reassemble in reverse order Headlight bulb H4 upgrade-imageuploadedbytapatalk1394338066.316248.jpg
    is 100 mile!
    elizerr's Avatar
    2340
    Feb 2014
    Texas
    100
    301
    Low beam comparison looks good but I want brighter!
    is firen on the grill jack
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Did the same with the same bulb, no bending of tabs required. Bolted straight on.
    Sent from my SAMSUNG-SGH-I747 using HondaGrom.net mobile app
    Attached Thumbnails Attached Thumbnails Headlight bulb H4 upgrade-1394340723930.jpg   Headlight bulb H4 upgrade-1394340753382.jpg
    2014 grom-Black, custom paint coming soon
    2007 Subaru STI
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Pictures are at idle, they get quite a bit brighter while holding the throttle steady. I took mine semi closer to my cars, to show a little contrast on something other than a fence or wall.
    Attached Thumbnails Attached Thumbnails Headlight bulb H4 upgrade-1394340866374.jpg   Headlight bulb H4 upgrade-1394340877060.jpg
    elizerr likes this.
    2007 Subaru STI
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Ill deffinenty be doing an hid kit but this is a quick fix for the time being
    2007 Subaru STI
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Here it is, 26 bucks at AutoZone. Went for a test ride and am happy. The roads are still a tad wet here and that stocker tire does hook for sh!t haha
    Attached Thumbnails Attached Thumbnails Headlight bulb H4 upgrade-1394341084000.jpg
    2007 Subaru STI
    is KCCO
    hicksy712's Avatar
    1461
    Oct 2013
    Mt. Juliet TN
    201
    Good comparison pic. Agreed that it's brighter over idle. I too am hoping to scoop up a projector housing and eventually slip in a hid. But until then it's a good upgrade.
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Yeah I feel ya, I want the projector also but don't want the ones on ebay with the colored halo ring. Unless it has some ridiculously bright leds that feed the ring.
    2007 Subaru STI
    rynosaur's Avatar
    2393
    Feb 2014
    Texas
    1400
    81
    Those damn boomerangs are a pain to get clipped back in
    elizerr likes this.
    2007 Subaru STI
  1. Brighter Headlight replacement bulb
    By gromgroom in forum Grom Gear and Accessories
    Last Post: 10-08-2016, 08:42 AM
  2. Headlight bulb
    By gromhawk in forum Grom Talk
    Last Post: 07-07-2014, 11:43 AM
  3. another choice for those to upgrade kit
    By akanploy in forum Grom Performance
    Last Post: 01-18-2014, 06:13 AM
  4. OEM Honda projector headlight bulb question
    By ttt637 in forum Grom Talk
    Last Post: 10-14-2013, 06:09 PM
  5. Air Filter Upgrade K&N R-1100 - How to
    By Lanceoa in forum Grom How-To's and Guides
    Last Post: 09-12-2013, 08:45 PM
grom headlight
grom headlight bulb
honda grom headlight bulb
honda grom headlight bulb replacement
honda grom headlight upgrade
honda grom led headlight bulb
hs1 bulb upgrade
hs1 vs h4 bulb
