210mm rear shock
210mm rear shock
This is a discussion on 210mm rear shock within the Grom Gear and Accessories forums, part of the Honda Grom Garage category; Hello i want to lower my grom but i do not want the starch kit. if i use only the lowering link it wiil touch ...
Results 1 to 5 of 5
Thread: 210mm rear shock
    11426
    Oct 2016
    36
    210mm rear shock
    Hello
    if i use only the lowering link it wiil touch the tire.
    i was thinking to change the rear shock from 250mm to 210mm.
    What do you think ?
    Thank you
    7608
    66
    You might need to get a shorter kickstand or cut your stock one.
    11426
    Oct 2016
    36
    why shorter kickstand ?
    5761
    Everett, WA
    41
    The frame is lower to the ground causing the bike to stand more upright with the kickstand down. The kickstand needs to be shortened to keep the proper “lean” with the kickstand down.
    11426
    Oct 2016
    36
  1. DR-1 rear shock
    By SHPL00P in forum Grom Performance
    Last Post: 11-15-2016, 02:51 PM
  2. Rear shock
    By Storm in forum Grom Performance
    Last Post: 03-18-2016, 09:34 PM
  3. Rear shock
    By F150ecobst in forum Parts for Sale / Wanted
    Last Post: 10-11-2015, 09:38 PM
  4. Getting the Rear Shock Off and On
    By echo in forum Grom Talk
    Last Post: 06-07-2013, 06:16 AM
  5. Rear shock length
    By Z50 in forum Grom Talk
    Last Post: 06-05-2013, 05:44 PM
