Considering Clip On Handlebars (suggestions)
This is a discussion on Considering Clip On Handlebars (suggestions) within the Grom Gear and Accessories forums, part of the Honda Grom Garage category; Hello World I'm a new member of the GROM family :sunglasses: and already on the hunt for mods. I was considering Clip On Handlebars. Has ...
Results 1 to 5 of 5
Thread: Considering Clip On Handlebars (suggestions)
    SacGROMmoto's Avatar
    11914
    Oct 2016
    Hello World I'm a new member of the GROM family :sunglasses: and already on the hunt for mods. I was considering Clip On Handlebars. Has anyone customized their Grom with Clip Ons?
    is bTuUsNaAnSuUtB
    Strokd_GE's Avatar
    54
    Central Florida
    2,923
    The typical "clip on" style doesn't work on a stock bodied Grom since the forks tuck into the body at full lock.. ComposiMo RaceBarz are a nice alternative
    11914
    Oct 2016
    Okay cool thanx for the suggestion
    Pigman's Avatar
    3581
    700
    You could prob run Helibars or something similar........
    jonesn's Avatar
    5717
    Missouri
    10k+
    55
    I run the composimos when my buddy and I go racing around. I would prefer an adjustable set however I was/am still very happy with them. It definitely gives it more of a supersport feel while riding around. Couldn't drag elbows on regular bars but I could with these.
    2015 Honda Grom, 12.6k miles (12-2-16) KOSO 170 2v, K- filter, K-connecting tubes, K-Camshaft, Finbro ECU, DG V2 Low Mount, Kitaco Cover, Takegawa High Flow Oil Pump, 10 hole injector, K- 34mm Throttle Body, K- 34-30.5mm intake manifold, PSD Subcage, PSD dual caliper bracket, Magura HC1 13mm handbrake, P34 brembo caliper, all stainless lines (goodridge), KX high pro taper fat bars + much more.
    http://www.hondagrom.net/forums/27-g...ace-build.html
  1. Clip removal on injector???
    By gromhawk in forum Grom Talk
    Last Post: 06-25-2016, 11:03 PM
  2. Trim Clip Removal
    By pwr2wh8 in forum Grom Talk
    Last Post: 02-19-2014, 10:20 PM
  3. Injector clip
    By nisson93 in forum Grom Talk
    Last Post: 02-13-2014, 03:25 AM
  4. Clip-Ons
    By Seanskeezy in forum Grom Talk
    Last Post: 06-06-2013, 09:29 AM
  5. Video clip.
    By 2quick2care in forum Grom Pictures/Videos
    Last Post: 06-04-2013, 09:19 AM
