Anyone have the DC rectifier from SteadyGarage?
This is a discussion on Anyone have the DC rectifier from SteadyGarage? within the Grom Gear and Accessories forums, part of the Honda Grom Garage category; Just got mine and installed it. Is it supposed to eliminate the rear tag light? Meaning my tag light doesn't work anymore. The tag light ...
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By turpinator
  • 1 Post By NJ_BenzTech
Thread: Anyone have the DC rectifier from SteadyGarage?
    is ordering more parts
    NJ_BenzTech's Avatar
    5527
    Jun 2015
    NNJ/GWB
    518
    Just got mine and installed it. Is it supposed to eliminate the rear tag light? Meaning my tag light doesn't work anymore. The tag light I'm running is LED, I'm not sure if that makes a difference. Let me know if any of you guys have come across this issue.
    5527
    Jun 2015
    NNJ/GWB
    518
    Nobody's got nuttin? I suppose I could re-wire the tag light but just need to know if this thing is faulty or not.
    mrclowny's Avatar
    6433
    Oct 2015
    Earth/NA/CA/LA
    331
    I'm not sure if this is related, but when I got my LED tag light, I needed to tap the wire from my new tail light wire as the stock tag light wires didn't work. I wonder if it's related somehow.
    5527
    Jun 2015
    NNJ/GWB
    518
    Yea I understand the tag light is run on AC from the stock rectifier. The LED tag light worked before (on AC voltage), but now no worky. I didn't check yet but if the new rectifier produced DC voltage at the tag light I'm thinking it would still work? Seems weird that the Gojin rectifier would eliminate the tag circuit (if in fact it does).
    1,921
    You have the old rectifier, right? Isnt it a pretty quick swap?
    I recall someone saying that the new one eliminates the need to convert the headlight voltage to DC if running LEDs or HID or something, right? (i dont know much about hid/actual automobile lights and stuff)
    If so, this voltage is the same that should be at the tag light (at the headlight i mean).
    Id maybe guess, it puts out DC on that wire now, and the LED in the back no longer works because of its polarity. It worked fine on the AC, with current coming from both directions.
    Time to get the meter out.
    NJ_BenzTech likes this.
    5527
    Jun 2015
    NNJ/GWB
    518
    Good point. I will check the polarity of the tag circuit now. I'll flip the connections and see what happens. That makes total sense, I'll mess with it later and follow up this post.
    TheMajekalBum likes this.
    5527
    Jun 2015
    NNJ/GWB
    518
    Flipped the tag wires, now it works. So this thing converts the headlight and tag light to DC. Thanks turpinator!
    teerex's Avatar
    5030
    Mar 2015
    Norway
    53
    That's a tag light mystery.
    I have the Yoshimura LED tag light. Instructions said to connect red to green and black to yellow from stock tag light wires.
    Thats opposite of normal DC polarity where red and yellow are positive, and green and black are negative.
    I guess the Yoshimura LED tag light has some kind of built in rectifier if it's supposed to work off AC?
    And the Gojin recitifer/regulator makes AC become DC, and then your LED tag light works when your wires are flipped?
    Tag light only comes on when engine is running. So why bother with polarity in the installation instructions if it's AC ?
    Stock tag light is a plain 5W bulb.
    2,632
    im assuming this regulator just uses the 3 wires IN (ac) .
    I have a 6pin generic voltage regulator that takes the sale plug., im wondering if i use this if it will do the same thin if I install it.
    HifiExpat's Avatar
    10969
    Middle East
    1500km
    171
    Quote Originally Posted by NJ_BenzTech View Post
    When I hooked up my OTB Halo front LEDs I had to run my unused tag light to give the HALOs 12v for the running light....so I figured the tag light was DC. I tapped into the rear harness with an extra connector since I don't run a plate or tag light. I have a THAI MSX125 that did not come with 3 wires at front blinkers, or an IAS.
    I've been running this way for months....
    Right now I'd like to remove my Cyclops LED and go with a different HID....just have to figure how this will affect my setup. Back to the top of this post again
    Sent from my Pixel C using Tapatalk
  1. Replies: 12
    Last Post: 05-10-2016, 05:35 AM
  2. Bride seat steadygarage...anyone have it?
    By Ronbang in forum Grom Talk
    Last Post: 02-01-2016, 07:57 AM
  3. SteadyGarage: Anodized Front Forks Black
    By TheOrangeBANG in forum Grom Talk
    Last Post: 01-16-2015, 12:19 AM
  4. Replies: 4
    Last Post: 05-21-2014, 11:55 AM
  5. AC to DC Bridge Rectifier for HID Lights
    By pwr2wh8 in forum Grom Talk
    Last Post: 04-01-2014, 09:17 AM
